Adjust battery charge indicator contrast.
(Topic created: 02-04-2025 07:29 AM)
Tom6068
Supernova
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
JUMP TO SOLUTION
MsVirgo87
Supernova
Galaxy S25
Yea I can barely see it and my eyesight is bad, I wish they gave us the option to change the colors and make it bigger
Robin621k
Honored Contributor
Galaxy S25
Maybe in Quick Star they will do something!
MsVirgo87
Supernova
Galaxy S25
That would be awesome if they do
Robin621k
Honored Contributor
Galaxy S25
Send feed back, tell them how you feel
MsVirgo87
Supernova
Galaxy S25
Where on here?
Robin621k
Honored Contributor
Galaxy S25
In the support tab in this app. Scroll down to Send Feedback
MsVirgo87
Supernova
Galaxy S25
Oh I never knew about that
usertI0gqLbpQ4
Galaxy S25
I like your time/weather/settings widget. What widget you are using. I cant find this one in my S25 ultra
RoryBreaker
Cosmic Ray
Galaxy S25
Another case of messing up something that was fine as is! Just got my S25 Ultra upgrading from the S24 Ultra. One of the first things I noticed is the Battery Percentage Icon has now changed from a VERY clean "NUMBER ONLY" display to a now crowded "NUMBER INSIDE OF A PILL" display.
This is a HORRIBLE decision. This makes the Battery Percentage much more difficult to make out. Samsung why would you do this and not give users an option to change it back???
tonyoo
Galaxy S25
Yes, this is an extremely stupid solution; totally unusable, invisible for me. I just want to see a pure number.
