Adjust battery charge indicator contrast.
(Topic created: 02-04-2025 07:29 AM)
Tom6068
Supernova
Galaxy S25
Hey All,
Is there a means to change the battery charging indicator in the notification areas to be opposite contrast. It is very difficult for me to see the indictor with black numbers on a white background.
JUMP TO SOLUTION
JesterPizzle
Comet
Galaxy S25
I just upgraded from the S23 Ultra to the S25 Ultra and I'm trying to get it all cleaned up and to my liking. Still trying to get used to One UI7. Does anyone know how to get rid of the battery icon in the top right of the AOD? I may have to wait until Lock Star comes back to do it but I'm worried about it burning into the screen if I leave it there. I've disabled the AOD for the time being. Also I wish they left it looking like a battery instead of changing it to a pill😡
Robin621k
Honored Contributor
Galaxy S25
Samsung employs pixel shifting. You don't have to worry about burn-in.
You can also go into the AOD settings and have it set to AUTO, this way when it is either face down or in a pocket, purse, etc. The AOD turns off. That is how I set it on my phone.
JesterPizzle
Comet
Galaxy S25
That's what I understood too but the battery doesn't seem to move since it's in the navigation bar and it's a fixed feature.
Robin621k
Honored Contributor
Galaxy S25
Pixel shifting is in the status bar.
Robin621k
Honored Contributor
Galaxy S25
Turn on Auto in AOD settings
Dan2023
Honored Contributor
Galaxy S25
If you're concerned about ghosting, perhaps you should set the AOD screen to 'Tap to wake'?
JesterPizzle
Comet
Galaxy S25
That's exactly what I did for now until the Lock Star comes back. 😊
W3
Cosmic Ray
Galaxy S25
What's the lock star and where can I find it?
JesterPizzle
Comet
Galaxy S25
Samsung LockStar is an app that lets you customize the lock screen and always-on display of your Samsung smartphone. It's a module within the Samsung Good Lock app. Unfortunately, right now it's only available for One UI6 and below.
GOOFY 12
Halo
Galaxy S25
To verify your pixel shifting is working, from screen shot settings turn off hide status bar and then take a screen shot. Toggle you screen off and on maybe 10 times. Bring up your screen shot and comparing the 2 images you should see the image has shifted slightly.
