Body composition won't load past 67%
(Topic created: 11-08-2023 05:01 PM)
DakotaDad
Galaxy Watch
I'm having many problems with the watch 6 Classic. I can never get past 67% when trying to take my body composition. It always stops there and gives me all sorts of reasons, like don't touch anything but the button or try wetting your fingers ,or raise your arms ,or,or,or........ While I'm at it samsung health used to announce current and average speed ( current speed 3.9 mph, average speed 4.0). It now only announces step count. Please bring back current and average speed. Thanks. I never had a problem on my watch classic 4 getting  my body comp. I hope it is a software problem and not physical.
Haybound
Cosmic Ray
Galaxy Watch
You're right. Even though I don't have the arm hair, it's still the only way I could get it to work. Thanks!
vAylpc3
Galaxy Watch
this WORKED! Turning the watch to inside of my arm... Thanks!
Members_zlQiXjU
Galaxy Watch
#2 worked perfectly, thank you!  I think if its dry out it messes with the contacts.
So what I would try:
1.) Clean area with alcohol
2.) Clean under watch with alcohol
3.) Wet wrist (just slightly wet)
4.) Flip watch around onto wrist.
The wetting part I believe is what worked for me.
Members_MztF6GQ
Galaxy Watch
Ok.  Been having the same issue on all my galaxy watches so far.     Think I finally figured it out.     Barely touch the buttons.      Whe. You press hard it times out.    Barely or lightly touching g.   Works everything.   Hope that helps
Escribblings
Galaxy Watch
Thank you, Members_MztF6G, This worked for me:
Quote: "Ok. Been having the same issue on all my galaxy watches so far. Think I finally figured it out. Barely touch the buttons. Whe. You press hard it times out. Barely or lightly touching g. Works everything. Hope that helpsthis worked for me. "
I have the 6 classic with a metal strap.  I have hairy arms and wear the watch on the right (my dominant hand, go figure).  And this was going my head in, I just couldn't get past 67%.
It's quite difficult to apply minimal pressure while keeping your arms up, the watch hand
Grahu27
Galaxy Watch
Total junk, body composition doesn't work no matter how I try, it gives error message. Blood oxygen says I'm at under 80% oxygen (which is a health emergency) everyday for a few times. Blood pressure app needs to be calibrated  every month with a blood pressure machine, if I had a blood pressure machine at home why would I need this watch. Totally useless piece of junk. Not worth the money. performs the functions that $50 watch can do. Super disappointed with Samsung
Members_26M4EUY
Galaxy Watch
I was having an issue with my Galaxy watch 5 where it would constantly fail at 67% and what I did is I flipped the watch upside down So that it would be on the bottom part of my wrist where there's no hair and when I did that it immediately worked. Try that.
Pwhiddy
Galaxy Watch
I had same problem every single time. I cleaned the sensors and still no luck. I finally moistened my skin where the watch was sitting and that worked. I do have a lot of hair on my arms so the only other thing I could think was to shave where the watch sat. LOL
UncleBeano
Galaxy Watch
I have the same issue
userkyrXekyHlx
Galaxy Watch
It used to work. Now I have the same problem. You would think SQA would exist at Samsung.
