8000 series (2018) TV Ethernet speed
(Topic created: 02-27-2019 04:06 PM)
rickatk
Halo
LED and OLED TVs
Does anyone know what speed the Ethernet port works on this series tv?
JUMP TO SOLUTION
Joras
LED and OLED TVs
You could have a million Mbps speed ad your  house but samsung tv's LAN port are old connections, there 100Mbps ports .. so the real speed will be when you divide 100 to 8 and that's  12.5MB end of story people ... deal with it ...  it does not matter if you have  cat5 or cat5e orcat6 or Cat7 cable ....
userip4oht5dAX
LED and OLED TVs
CAT7 cable not needed.  CAT7 is proprietary, lacks IEEE and EIA approval, and is not widely adopted.  CAT6 and CAT6a provide full 1G capability.
useriiRmkfsLTM
LED and OLED TVs
Will not run gbps. Only will do less the 100 Mbps. I've tried it all cat7 cable won't help.
dont buy one. Totally false claim.
userIgcT4ILgHn
LED and OLED TVs
my tv Q90T 75"WITH CAT 7 ETHERNET CABLE NOT REACH MORE THE 60Mbs on speed test on internet samsung ,my  internet normal speed is 460Mbs
rickatk
Halo
LED and OLED TVs
Try a Cat 6 cable.
Try wifi just to see if the ethernet connection is inherently slow.
Doba
LED and OLED TVs
I have the NU8000, juts got a gigabit connection, pretty sure I'm running a cat6 cable, have to double check, last night my speedtest via ethernet was ~140Mbps, but with wifi I reached ~170Mbps which I was hoping for more, but reading here I seem to be getting more than most, So no way I can see closer to my 1gig?
ARSY51
LED and OLED TVs
I've got a UN55MU8000 and was wondering if you use a USB-to-Ethernet Adapter (that supports 10/100/1000 Mpbs), can you achieve speeds faster than 100 Mbps via USB vs the TV's ethernet port?
userVN6Ar4gmHS
LED and OLED TVs
Q7N TV Core issue was YouTube TV issues. Internet speed over WiFi or Ethernet is 500 to 600. However using TV browser speed test max on Ethernet was 95. Switched to WiFi and speed is 225.
Am I right to understand max TV Ethernet port speed is 100? That is why WiFi is over double?
But why isn’t WiFi speed higher? All my other devices measure 5 times faster?
Joras
LED and OLED TVs
Yes Samsung Tv's new and old are 100Mbps LAN port ... i have been looking in to this for more then 2 years ...  ports .... and remember 100 Mbps port you have to still divide them in too 8 to get the real MB speed and that is 12.5MB per second ... yes it  ....
hclark1160
LED and OLED TVs
glad i found this post, just subscribed to paramount+ and am having all kinds of problems streaming the on demand tv shows. i am using the ethernet port but think it is what is causing the trouble. going to try wifi too see if that is any better
