Pj424
- Mute
Monday in
Home Theaterhi,
after connecting with HDMI cable from AVR slot on "VU Tv" with HDMI out port in "samsung ht-e350k DVD home theater" still sound was not audible..
is it correct connection for this old home theater models.
can we do any procedure to connect the VU tv with this home theater, please suggest best one.
1 Reply
MrXGeekX
Galaxy
- Mute
Tuesday in
Home Theater
To connect your VU TV to the Samsung HT-E350K home theater system, first use an HDMI cable to connect the HDMI OUT port on the home theater to an HDMI IN port on the TV. Ensure the TV is set to the correct HDMI input and enable HDMI-CEC on both devices if available. If HDMI doesn’t work, try using an optical cable from the TV's optical OUT to the home theater's optical IN, or use RCA cables for audio. Check the TV's audio settings to ensure it is set to the external speakers or home theater system, and power cycle both devices.
