Bespoke 4-door Main Panel how to change temperature to Celsius
(Topic created: 02-07-2024 09:09 AM)
RB19
Kitchen and Family Hub
Hi there,
I have a brand new Bespoke model RF29BB8600QLAA and want to change the temperature to Celsius. According to the user manual, you touch the temperature until it cycles to the desired unit. It's not happening. How do you change it form F to C?
Thanks
Samsung_Moderator
Hello! Thank you for reaching out! You should be able to change it by pressing and holding the freezer button for at least 3 seconds to get it to change. Please let me know if this helps!
Samsung_Moderator
RB19
Thank you! It worked!
Samsung_Moderator
That's great to hear!
