Dishwasher DW80R9950US--HOW TO LEVEL
(Topic created: 11-19-2022 09:21 AM)
userTMrNOv0TM0
Kitchen and Family Hub
I am installing a new dishwasher with feet in the front but no feet in the back to adjust the height of the dishwasher by about 3-8 of an inch. If I adjust the front feet so it reaches the bottom of the granite it will be not level front to back.
Samsung_Moderator
Hi there, Thanks so much for reaching out about this. I can certainly understand the need to have your dishwasher properly leveled. I'm providing a link below to our guide for this. It has everything you need to know about getting your dishwasher leveled correctly.
https://www.samsung.com/us/support/answer/ANS00080768/
user751201tmO21
Honored Contributor
Seems the floor is not level.
Use adjustable shims at the rear
Samsung_Moderator
