French door fridge stuck in demo mode
(Topic created: 06-26-2021 09:29 AM)
userlUv0YWJf4s
Kitchen and Family Hub
My French door fridge model RF23M8070SR is stuck in demo mode. Display will flash when we try to reset but no chime. Please help
SamsungCaleb
Thank you for reaching out the information in the link below should be most helpful as it will show you how to turn demo mode on or off:
https://www.samsung.com/us/support/answer/ANS00048861/
1 Reply
SamsungCaleb
