Stove issues - HOT SURFACE light will not go off
(Topic created: 04-28-2022 06:26 AM)
pEwglj3
Kitchen and Family Hub
Hello
  My Samsung glass flat top stove HOT SURFACE light will not go off after two days.  How can I fix it?
Samsung_Moderator
I can definitely understand how frustrating this may be. If you unplug the unit or cut the power to it at the circuit breaker for about 5 minutes, then retry it, does it work as intended? If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case by case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
1 Reply
Samsung_Moderator
