Range clock will not stay on.
(Topic created: 06-24-2024 07:55 AM)
43829290
Kitchen and Family Hub
I have a brand new Bespoke gas range - NSG6DG8700SRAA.  The clock will not stay on.  The display times out after a few minutes.  I would like the clock lit 24/7.
ron11
Me too!
Members_bVcGqv9
Me as well.
a27
I bought a Samsung Bespoke gas range (NSG6DG8500SR) and cannot get the display to stay on either. The manual says: "The control panel enters Sleep mode if the oven is not used for a while. In Sleep mode, the control panel is inactive until it is reactivated by the user."  My interpretation is that sleep mode is not optional, but my opinion, it should be. It's my oven! I should be able to control something as basic as keeping the display on. I doubt they'll ever give us that control because they're probably trying to preserve the life of the LCD screen and they don't want it to fail under warranty. But considering the amount of money that these ovens cost, Samsung should have solved this by now.
emcmullen
We just got our Bespoke Induction Range and the clock goes to sleep on ours too. So obnoxious.
aarrow
Same here i just biught mine. Is there a fix or work around? Or even a response from samsung?
mamamia25
same
cmorgando
Access the settings menu by touching the gear button / turn the dial to scroll to the screensaver option / turn on by pressing the dial.
tswidler
I want that too. The most annoying thing is that the clock turns off. Please make a firmware change for that.
userh6XZaEvQMN
I am about to return the gas range because of this issue
