Samsung bespoke 4 door French refrigerator
(Topic created: 04-09-2025 12:33 AM)
Rouse912
Kitchen and Family Hub
Anyone experience the water dispenser randomly acting as if it’s almost out of water and making a loud noise? Fridge is 1 week old. Samsung support was useless.
Video for reference. It does not do it every time it’s used. Just started today after 1 week of use.
https://share.icloud.com/photos/0c1sW3xUVnS-UF-ejSFLddhWg
1 Reply
Samsung_Moderator
Hello Rouse912 and Welcome to our Samsung Community. The issue you're describing likely is caused by trapped air in the water line. When the refrigerator was installed did you purge the water line?
To purge air from the water line, hold down the dispenser lever and attempt to dispense water for 5 minutes. As the water begins to dispense, continue until all sputtering stops and the stream is steady (which may take up to 2-3 gallons).
Please let me know if you've already performed this step previously; as the next recommendations are to contact the installer for a thorough inspection of the water line or click this service link- https://www.samsung.com/us/support/service/
to request a technician.
