- Mute
yesterday in
Kitchen and Family HubI bought the flex oven duo, and the air fryer function made a splatter all over which spilled through the sides at the bottom. I cannot figure out how to clean this, and I don't want to use the oven since the spilll will just burn more
Solved! Go to Solution.
![Community Manager Community Manager](/i/rank_icons/admin.gif)
- Mute
yesterday in
Kitchen and Family HubHello @elidemr! Thank you for reaching out! Unfortunately, I am not seeing that the floor panel on the range can come off without taking any screws out. I would recommend looking through your user manual to help clean your range. You can use the link below to see your user manual.
- Mute
yesterday in
![](/skins/images/DB93CB5B34A5AEDFF8D2EC56A6AA1E31/responsive_peak/images/icon_anonymous_message.png)
