How to turn off ice maker in freezer - model RF28R6241SR*
(Topic created: 09-28-2020 08:22 AM)
userPDOXpIOMS1
Kitchen and Family Hub
Samsung 3-door French refrigerator Model # RF28R6241SR/AA
Problem:  how to turn off the freezer ice maker.
I have two ice makers in my appliance.  I would like to turn off the freezer ice maker.  There are no instructions in the owner’s manual.  Samsung advised me to pull out the freezer ice bucket.  On the right side of the ice maker, I should see a switch and should  move it to the O position.  I see no switch.  What do I do now?
MsBri1
Neutron Star
On your display panel inside the unit tap where it says Ice Maker until the first Ice Maker On icon is lit. (see image below)
MsBri1
Neutron Star
userPDOXpIOMS1
The solution did work after I unlocked the control panel.  I have to hold the Ice Maker for several seconds to disable the top ice maker; then hold the Ice Maker icon a second time to disable the freezer ice maker.  I then reactivated the top Ice Maker.  Thanks!
