Water container in the door of refrigerator
(Topic created: 01-11-2024 05:19 PM)
userblOAN5UVle
Kitchen and Family Hub
I have a French door refrigerator with a water container in the door.i need to replace the container I do not know what Samsung calls it so I can't refer to any list to find a part number does anyone have any suggestions.
Samsung_Moderator
Hello @userblOAN5UVle! Thank you for reaching out! This is called the Auto Fill Water Pitcher. You can purchase one at samsungparts.com
autofill pitcher??
FAUguy
Galaxy
Why is this in the Samsung S22 forum?
Samsung_Moderator
