80" TV loud pop no longer working
(Topic created: 03-26-2025 01:03 PM)
Bigchief73
LED and OLED TVs
3/4 years a go we purchased an 80: Samsung for our theatre room.   The room is only used during football season and the occasional movie night ever month or 2.  There is less than 100 Hours on this tv and it has already stopped working.  The worst part is I believe the WARRANTY is over.   Has anyone had this experience happen to their TV.  For a tv with this limited amount of use is very frustrating and disappointing.
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
Sorry to hear this happened to your TV from what you said it sounds like the Power supply might have blown inside the Tv which caused the loud pop I would suggest contacting a Service center to have the TV checked and since its been 3-4 years I expect the warranty to be over since they normally only come with a 1 year warranty
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
1 Reply
GaryB82
LED and OLED TVs
