- Mute
11-01-2020
04:55 AM
(Last edited
12-03-2023
11:03 PM
by
SamsungChelsea
) in
Hi.
I recently bought a new Samsung 2020 model with airplay 2
I cannot longer have mirror screen functioning with my iPhone.
the tv model appears in my device but it says that it is not possible to connect
They are both connected to the same Wi-Fi.
Solved! Go to Solution.
- Mute
11-03-2020 11:40 AM in
LED and OLED TVsHello, to better assist you can you please provide me with your full model code?
- Mute
- Mute
11-04-2020 01:41 AM in
LED and OLED TVsProblem solved.
I had to power off the iPhone, restart and then the problem was solved.
But i still don't understand why they didn't connect.
![Samsung Moderator Samsung Moderator](/i/rank_icons/moderator.gif)
- Mute
11-04-2020 11:39 AM in
LED and OLED TVsThat's great to hear!
- Mute
12-29-2020 05:16 AM in
LED and OLED TVs43" TU700D Crystal UHD 4K
![](/skins/images/2F3847E95409C09C823270C9561E7CCE/responsive_peak/images/icon_anonymous_message.png)
