Display blinking when connected to PC via USB-C to HDMI 2.1
(Topic created: 02-15-2025 11:43 PM)
Gumball2452
LED and OLED TVs
I am using a PC connected to my Samsung S90D TV via a USB-C to HDMI 2.1 cable. It works fine right when the cable is plugged in or right when the computer turns on, but if I turn off the TV, wait a few minutes, and turn the TV back on, the video output starts blinking randomly. The issue is resolved when I reseat the cable or reboot the computer. This happens with 3 separate PCs - one running windows 11, one fedora, and one bazzite, so I don't think the PCs are at fault. The issue does not happen when plugging a hdmi cable directly into the hdmi port of my mini pc. It only happens when I use this usb c to hdmi 2.1 cable.
Not sure if related, but with the same cable, I've also been occasionally having an issue where it won't pass any audio to the TV. Sometimes rebooting the PC fixes this, but sometimes not.
I do not believe there is anything wrong with the cable because I tried plugging my computer into a 4k monitor I have with the same cable, and was unable to reproduce the blinking issue.
Is there any setting I can change on the TV that will fix this? I tried updating it, which didn't help. I tried lowering the resolution from 4k120hz to 4k60hz, which also didn't help. The hdmi-self diagnosis test didn't find anything either. I'm using game mode and the input is set to PC.
Also, just to clarify, the reason that I want to use this cable specifically is because the hdmi port built into my mini pc (minisforum UN1265) maxes out at 4k60hz, while the USB C port can do 4k120hz.
Gumball2452
LED and OLED TVs
The cable matters usb c to hdmi cable fixed the issue for me.
https://www.amazon.ca/Cable-Matters-HDMI-Support-240Hz/dp/B0CT6CK72N
1 Reply
Gumball2452
LED and OLED TVs
