Need to turn off all Samsung TVs at the same time
(Topic created: 09-13-2024 09:18 AM)
ajr_splc
LED and OLED TVs
We have four Samsung TV/monitors in our sanctuary. We would like to be able to turn them all on and off at the same time with one remote. Is there a cost-effective way to do that?
ajr_splc
LED and OLED TVs
Thanks for all of the suggestions. I got the Smart Things app and that is doing everything we need. We especially like that we can schedule routines to turn the TVs off and on at a particular time, and group them in those routines.
realaud
Honored Contributor
LED and OLED TVs
Plug them into smart plugs, put them into a group in the smart things app and then turn the group on/off using the smart things app or the smart plugs' app on your phone.
Please mark any response that helped you as your solution.
Ekamek
Neutron Star
LED and OLED TVs
Like @realaud said, getting a Samsung SmartThing device or a generic smart hub to control them should be your easiest option.
ajr_splc
LED and OLED TVs
