Turning off 4k on Samsung Q60R TV
(Topic created: 01-24-2025 12:33 AM)
kdbtiger
LED and OLED TVs
I have a Samsung Q60r 2019 smart TV. I would like to turn off  all 4k options to make it a 1080p HDTV. I can't find this anywhere in the settings. How is this done?
kdbtiger
LED and OLED TVs
Yes. That worked. Thanks.
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @kdbtiger Thank you for posting about this. You would need to  change the resolution on your external device/ apps. Navigate to All Settings, then select Picture, and then select Picture Mode.
Please let me know if this helps
kdbtiger
LED and OLED TVs
