- Mute
ā02-25-2025
09:58 PM
(Last edited
ā03-05-2025
10:53 AM
by
SamsungCaleb
) in
For the past 2 days, I've been getting an EXTREMELY annoying popup notification with small ding sound. This pops up about every 2 hours and disappears in 5 seconds. Impossible and just plain silly to not be able to read it. It does say something about thanks for being a customer and that smart hub collects data in some kind of way and that you can mess with settings in settings. I have never been able to read it as it leaves so fast. I just disconnected it from my network prior to posting this. Anyone knows what this is and most importantly, how to stop it?
I only hope that disconnecting it from my network will stop these messages but only thing I can find under privacy settings want me to agree to a bunch of check marks. I clicked none of them as I do not agree with their TOS for something that I rarely use. This TV is strictly as a monitor and have no antenna connected. I could completely disable smart hub as I may just have by disconnecting the network connection.
UPDATE EDIT:
Taking the TV offline seemed to have fixed the issue but the loss of IP remote control via watch and home assistance is an annoying too. My plan is to Block the TV's mac address from any WAN (Wide Area Network) access via my router. I'll put it back on the network so that my home assistance setup still has access to it so I'll still have my remote control features but the TV and Samsung has no access to and can't make changes to my purchased and owned property.
The TV is used as a monitor like I said so a dumb tv will be fine if I can't get it to work how I mentioned. I'll update if anyone even cares about that route.
UPDATE 2: I have since reconnected my TV back to the network and instantly saw the warning again. I then blocked WAN access of the TV via my router but it is connected to my LAN only.
I then disconnected my phone offline to test and still have access to my Home Assistant features to the TV online as that is via a encrypted DDNS running through my own micro PC setup along with every other former cloud device I own. All controlled by me. Now Samsung can't break what they can't connect to.
Solved! Go to Solution.
- Mute
ā02-26-2025 07:09 AM in
LED and OLED TVsHaving/Had same issue
I went into All Settings > General &Privacy > Terms & Privacy > Smart Hub U.S. Privacy Notice and clicked through all the options so that the TV registers that I have reviewed all the privacy notices. Then Close out of it
I haven't seen the pop up after this. BUT, as mentioned the pop up only appeared for like 5 seconds so if I wasn't staring at the screen I might have missed it. Time will tell
- Mute
ā02-26-2025 08:11 AM in
LED and OLED TVsReply, that's what they want. Us to go and agree to all the information. I sure it includes some type of arbitration information and such. I don't agree with it and don't use the smart hub. They make an annoying pop up that will bother us until it is agreed to. I just disconnected my TV off of the network and haven't seen it since. If this does remedy the info. I'll just block this tv from online access via my router but keep it connected to my home assistant so I can still control it via remote. A work in progress. I'll see if disconnecting actually fixed the issue.
- Mute
ā02-26-2025 10:35 PM in
LED and OLED TVs- Mark as New
- Mute
ā02-27-2025 05:24 PM in
LED and OLED TVsI followed your advice, clicked all the terms and options, but I still get the popup.
- Mute
ā02-28-2025 03:15 PM in
- Mute
ā02-26-2025 08:26 AM in
LED and OLED TVsI just got off Samsung support chat. They are boosting this to tier 2 level and I should hear back from them in a day or two. If you do the same, be sure to get a ticket number for reference.
- Mute
ā02-26-2025 09:07 PM in
LED and OLED TVsI captured the message on my QN900B. Attaching here in case it isn't seen elsewhere.
- Mute
ā02-26-2025 08:32 AM in
LED and OLED TVsFor reference, the exact message which I managed to capture is
Thank you for being our valued customer. As a reminder, and as mentioned in the Smart Hub Privacy Notice (found in the TV settings), we may collect information about how you use this device and the services you use on it."
The support assistant wanted the exact wording and a screenshot, which I uploaded.
- Mute
ā02-27-2025 06:43 PM in
- Mute
ā02-26-2025 08:44 AM in
LED and OLED TVsI had the same message pop up on my TV last night.
There is nothing to confirm. It just appears and then disappears in a few seconds.
