Problem with new TV - bright light on bottom
(Topic created: 11-22-2022 01:40 PM)
SusanJean
LED and OLED TVs
I just purchased a Samsung 40 inch HD TV.  The picture looks great but there is a bright light on the bottom.  What is itIMG_5165.jpeg
NPC1
Red Giant
LED and OLED TVs
Is probably the edge lighting showing through. You should get it replaced.
NPC1
Red Giant
LED and OLED TVs
Diaboyos
Honored Contributor
LED and OLED TVs
That's edge bleed and pretty bad. If you just got it I'd return it.
