Tv will stop for a few seconds
(Topic created: 09-13-2024 05:44 PM)
AmaliaK
LED and OLED TVs
Hi! I have a Samsung tv that recently when I run streaming apps (DirectTv, Amazon etc), it will randomly freeze, a blue line goes across the bottom like it’s thinking then it will return but it’s very annoying. Sometimes it will stop completely and say an error has occurred. Wifi is connected, no other tv, my tablet have that problem so I just don’t think it’s the wifi.
Samsung_Moderator
LED and OLED TVs
Hello @AmaliaK! Thank you for reaching out! I would recommend making sure that your TV is connected to the 2.4GHz Wi-Fi network first as the 5GHz network can have issues like this. I would also recommend going through the troubleshooting in the link below.
https://www.samsung.com/us/support/troubleshoot/TSG10000062/
Samsung_Moderator
LED and OLED TVs
AmaliaK
LED and OLED TVs
Ok thank you! How do I know if it is connected to and make sure it’s on the 2.4 and not 5?
Samsung_Moderator
LED and OLED TVs
Most networks will state which is 5G, an example with be like "spectrum-5G" unless when setting up your router it was changed manually.
AmaliaK
LED and OLED TVs
Just want to say thank you! This seemed to have fixed it. Not sure why it wasn’t an issue until recently but oh well, thanks
