Red light on bottom of my oled tv
(Topic created: 11-30-2024 06:09 AM)
Jeff3655
LED and OLED TVs
When my tv is powered off the red light in the bottom corner stays on- is this normal?
realaud
Honored Contributor
LED and OLED TVs
That is the standby light to let you know that the TV is powered.  My TV (not a Samsung) has a setting to turn the light off, check your manual and/or settings to see if your TV has such a feature.
Yaswanth
Galaxy
LED and OLED TVs
Yes. It is normal
realaud
Honored Contributor
LED and OLED TVs
meself
Honored Contributor
LED and OLED TVs
Rather common feature on many brands some allow you to turn off the stand by light
