Samsung 65" Smart TV - Info window keeps opening with Hulu app
(Topic created: 10-30-2024 02:49 PM)
Thrillho
LED and OLED TVs
Hi All,
I'm having an aggravating problem.  For the past week or so, when watching Hulu the info bar keeps randomly popping on and off (as if I'm hitting the "up" button to check the time/channel/etc.).  See photo below.  I tried reinstalling the app and unplugging the TV, but it still happens.  No other apps or TVs in the house have this problem.  We've had no problems whatsoever with our internet.
TV model is UN65DU7200F in case needed.
Any thoughts?  Thanks in advance!
Samsung_Moderator
LED and OLED TVs
I'm sorry to hear that I would recommend reaching out to Hulu support for more support!
Samsung_Moderator
LED and OLED TVs
I definitely understand your frustrations with this and am delighted to assist you! With you having already uninstalled the app and power cycled the TV; have you check to verify your TV is up to date on the firmware/software? It's possible that it needs to be updated and this may correct the issue presented. In the event there is no update needed to the TV, it would then be an app issue since it's only happening on Hulu. You will need to contact the app developers as they may be able to see if they can assist you further.
Thrillho
LED and OLED TVs
Thanks for the help.  I actually tried resetting the router, and that may have worked.  No issues for a couple days now.  Hopefully resolved!
Thrillho
LED and OLED TVs
Unfortunately, the problem started again after a week break.  I did double check the software, and it is up to date.  I will contact Hulu to see if they can help, unless there are any other recommendations...
Samsung_Moderator
LED and OLED TVs
