Samsung TV Plus Not Active in one TV but it is on another
(Topic created: 05-19-2024 09:41 AM)
frread
LED and OLED TVs
I bougth 2 CU7000D Crystal UHD 4K Smart TV one 75 and one 55,
but for some reason i get samsung tv plus only on the 55 inch one.
They are both connected to the same network and same samsung account, and both have the same software installed.
only difference is the 75 inch has a cable box installed and the 55 does not.
how can i activate samsung tv plus on the 75 inch one
frread
LED and OLED TVs
I was able to contact support and the issue was fixed, the tv was in the wrong region.
bill-e
Cosmic Samsung Care Ambassador
LED and OLED TVs
Have you gone into Apps->Settings->App Settings and checked that it  doesnn't  need to be downloaded and installed?
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
frread
LED and OLED TVs
Yes, i have checked and its not even there.
frread
LED and OLED TVs
