- Mute
03-15-2025 10:26 AM in
LED and OLED TVsWHO is having this issue with LED lights showing in the background
Solved! Go to Solution.
- Mute
03-20-2025 10:19 AM in
LED and OLED TVsHello @Soulfinger! Thank you for reaching out! If this is occurring on all sources this is something that will require service. Depending on your warranty you will have a few options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
- Mute
03-17-2025 10:02 PM in
LED and OLED TVs- Mark as New
- Mute
