Updating your television can be frustrating. Here are a few steps to help with downloading the firmware from the Samsung website to your USB drive.... View Post
Custom List Message Item |
Updating your television can be frustrating. Here are a few steps to help with downloading the firmware from the Samsung website to your USB drive.... View Post |
Quick solution: 1: All Settings 2: Connections 3: External Device Manager 4: Input Signal Plus (OFF)... View Post |
After just eight months, my S90C developed a red square on the lower right side of the screen. Samsung refuses to help — their customer... View Post I ordered a TCON board, hoping it will fix the issue. It makes me sick to think my $1,800 TV is brok... View Post |
This seems to be an issue for many. When Ambient mode is enabled, it will change the image every 60 seconds or so and there is no way to stop it. I... View Post Hi there, Thanks so much for asking about this. I'm providing a link below to our guide on Ambient M... View Post |
Hi, just bought an oled 65in S90DD tv. and I would like to know how to remove the channel info banner that pops up every time for about 2 seconds... View Post Thanks for the quick reply. Since you're using an Android device, there's a few different ways you c... View Post |
My remote is working totally fine except for volume button (up/down/mute). I reset my TV and the volume button worked fine after that…only to stop... View Post |
Model: UN58TU7000F I tried: - Unplugged, waiting for several minutes then plugging it back. - Factory reset - Soft... View Post Hi there! Thank you for reaching out. I know how aggravating this is and am happy to help! Have you ... View Post |
Hi everyone, I noticed my Samsung TV appears twice in my Samsung account, but with different names: 1. Before signing... View Post |
Is there any way to permanently disable the Accessibility Menu Shortcut Key (hold mute for 3 seconds)???? My 80 year old mom keeps... View Post You are very welcome! Thank you for trying! And will reach out to them. Have a good day! View Post |
Hello, When watching programs, I notice the lip movement & spoken words are off sync, are there any adjustment that can correct this issue? ... View Post |
I just spent 2 hours with Samsung Support and YouTubeTV support on 1-28-2025... At the end of my YouTubeTV support session, the YouTubeTV support... View Post Several post in several fora show that this is a tizen issue and not dependent on model numbers. I h... View Post |
For the past 2 days, I've been getting an EXTREMELY annoying popup notification with small ding sound. This pops up about every 2 hours and... View Post My Samsung TV is less than 4 months old and I've recently over the past week in the top right corner... View Post |
The equalizer is all greyed out. I can change the subwoofer but nothing else. View Post Hello! Thank you for reaching out! Can you please check if you are using standard sound mode, you ca... View Post |
Was watching TV and the TV just shut down. Checked plugs - outlets - connections - etc...and getting nothing. No red light - no sign of life.... View Post Hello @ccurti! Thank you for reaching out! This is something that will require service, depending on... View Post |
Ref: My model TV: UN43DU7200D Remote doesn’t control all functions of my Comcast/Xfinity cable box and I have to use my xfinity remote along... View Post |
HG55Q60A TV "Network" is grayed out. And no option coming for factory reset. Any help is appreciated. It is a brand new tv, It was not... View Post Hello! Thank you for reaching out! I would recommend attempting the troubleshooting in the following... View Post |
Just bought a Samsung S95D and the TV does not reliably turn on through HDMI CEC ... I've tried using an Apple TV and a Playstation 5, both of... View Post Here is my proposed solution = Ask the Apple engineers to Change the “On” small button on top right ... View Post |
I tried to post a comment on similar posts but they were marked closed. Posting this in case anyone else has this issue. Our issue: even with... View Post |
This notice keeps popping up on my TV screen. "Thank you for being our valued customer. As a reminder, and as mentioned in the Smart Hub... View Post I think Samsung may have solved the problem, I haven't seen the popups the last 2 days. Hopefully it... View Post |
Did a factory reset because the tv menu was not responding. TV is now stuck on Step 3 and unable to clear/ go back, or reset again. Prior post... View Post Thus worked for me. Thanks! Did your steps then just skipped everything during setup and manully con... View Post |
Hi Everyone, Has anyone else had this happen? Two days ago, my TV prompted me for an OS update and mentioned it would update when the TV was... View Post Did you get an answer as to your issue? I have an S89C with a black screen, but with sound. I've rep... View Post |
I am considering a Samsung QN85D television. I have the Roku Ultra, and will be using it instead of the built-in Samsung Tizen system. Also will... View Post the TV won’t repeatedly nag you, but there might be occasional reminders about smart features if the... View Post |
I have the model Ln46c530f1fxza and it is from 2010 Everytime I turn it on, there is a start up sound that is too loud and waking up people in... View Post Hi @misterno. Unfortunately if the disabling the sound through the menu didn't work, service may be ... View Post |
