The Frame TV remote Right button not working on either remotes
(Topic created: a month ago)
rob1platt
LED and OLED TVs
I have just bought a The Frame TV and immediately after setting it up, both the white smart remote and the black back-up remote Right buttons have stopped working. I can control the TV from my phone but that is not a good solution as it means that I'm the only person that can control the TV. I notice many other posts with similar issues that just say reset the remote but that cannot be the case as it is both remotes. Anyone have any ideas or similar issue that you managed to solve? If so, how?
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @rob1platt  Thank you for posting about this. I completely understand your concerns with the both remotes not working. Can you reset both remotes?  For the smart remote hold the back and up buttons simultaneously for 10 seconds to reset the remote. Back up remote removed the batteries and press and hold the power button for 10 seconds, and then reinsert the batteries.
Check for interference ensure there is no physical obstruction between the remotes and the tv. Also, make sure the the firmware is updated. Go to Settings> Support> Software Update and check for any available updates.
Please let me know if this helps
SamsungTam
Honored Contributor
LED and OLED TVs
Phaithos
LED and OLED TVs
I had a similar issue where my right button wouldn't work on the remote but everything else did. It ended up being something to do with the digital remote function on my phone. Using the app, I clicked around for a second randomly and then my smart remote started working as expected.
I've seen others complain that something seems to get hung up on the phone app side and it causes the normal remotes to not work as expected.
