YouTube TV stopped working
(Topic created: 06-16-2024 10:39 AM)
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
Greetings,
I have a Samsung QN90AA 50 Tv and YouTube TV. Up until last night it had worked for some years.
Now there is no video or sound. The guide shows up and all the settings tabs and so on. There is even the option to resume a previously viewed show and I can click on that.
No video at all. It is stuck on  a black screen with the little circle spinning.
If I click on the resume show windows, there is a commercial for some 3 minutes. The commercial video shows. No problem. there little timer is there to show the 3 minutes going by. Then upon completion, the screen goes black with the spinning circle.
I have done the following: power recycle, reinstall, clear cache, delete Smart Hub and reset to factory specs. No change.
In looking at the nerd information there is NO "Network Activity" The connection speed shows as well as the buffer health.
Also, YouTube TV works fine on my Samsung S21, desktop, laptop, tablet and Roku device. No problem.
The Samsung TV is connected via hardware to the router. There is WiFi also. Tried both connections. Just in case there was a hard wire issue. Zero luck there.
Up until now, there was not any issue. Download speed is about 120 Mps and upload is about 60 Mps.
Tom1230
LED and OLED TVs
I do not know why Samsung techs don't tell people to do this, but it worked for me. I found this from another thread for a different Samsung TV model. It solved the issues.
SAMSUNG TV โ€“ FLASH MEMORY RESET
Steps:
  1. With the TV turned on, press and hold the power button on the bottom edge of the TV until the control panel menu appears on the screen that includes a power on/off icon.
  2. Release the button and have the TV remote handy as the control panel menu disappears shortly after it appears.
  3. While the control panel menu is showing, press and hold the power button on the TV remote for at least 5 seconds until the TV shuts off and the screen goes black.
  4. The TV will restart after a while and reboot.
  5. After the TV reboots you will have to go through and set up the TV as if it were new.
Note: This clears out the flash memory and junk cached files that accumulate and donโ€™t get cleared out with the app cache clear step when going through the TV settings menus.
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
I just checked YouTube (not TV) and it works just fine. No issues.  I opened up the nerd info tab and attached a photo.
The distinct difference in the Network Activity. For TV, there is none. For regular YouTube, there is activity.
There is a clear problem with the Network Activity being blocked somehow.
Jacob126
Nebula
LED and OLED TVs
Maybe your TV is to old?
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
I bought the TV new in summer of 2021. I should hope the lifespan is longer than that.
I have a ticket submitted to YouTube and they are looking through all the logs I sent.
Jacob126
Nebula
LED and OLED TVs
So then wait for a reply
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
Based on what you wrote I went to the YouTube TV web site and Samsung TVs after 2017 are compatible.
I posted thus to see if anyone had a thought in addition to an FYI.
I am waiting. Thank you.
P.S. Complete TV reset to factory settings did nothing.
LeoWyatt89
Comet
LED and OLED TVs
if you have tried reinstalling the application? If you've done that and your software is up to date on your television there's nothing else you can do on your end, Report it to Youtube. Nothing samsung can really do either.
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
I have a ticket in with YouTube and it has been escalated. In addition, I have a ticket with Samsung as well and it also has been escalated.
The purpose of my post is partly to seek assistance and also to have on record with searches about the problem's existence.
Thank you
Grandroid
LED and OLED TVs
I have this exact same issue on my 2021 85 inch QN90AA, it began last weekend following a power interruption. I am able to run my Youtube TV on four other TVs, three of them Samsung, one LG and can also run Youtube TV on my Nest Hub.  The problem is squarely a SAMSUNG QN85AA issue, based on my troubleshooting.
userTyjRDHrnE6
Cosmic Ray
LED and OLED TVs
Thank you for adding you experience to mine.
I have contacted YouTube TV multiple times with tickets in place.
I have reset the TV to factory specs. No luck. I cannot think of anything else to do. My Roku works, of course, but I took that from the guest room (no guests right now).
I submitted a ticket to Samsung as well. Nothing.
I have a near zero expectation of a resolution.
Cheers
