"No signal” when I turn on my TV
(Topic created: 01-17-2025 08:28 AM)
mleppelman
LED and OLED TVs
Every time I turn off my TV (QN65S90DAF) or change to a different input I get the message to check my connection on my Tivo DVR.  To correct this, I have to pull the power on the Tivo or pull the HDMI cable and plug it back in If I pull the HDMI cable I have to go thru the full setup process.
I found this post, but I am unable to get the solution.
 “No signal” message for HDMI of connected TiVo DVR and Cable Box
Samsung_Moderator
LED and OLED TVs
Thank you for reaching out @mleppelman.  It sounds like it's an issue with your HDMI cables.  I had something similar happened when I used HDMI cables from the previous television.  Once I replaced them with some high speed cables, I never had that happen again.  Give this a try and let us know if this works.  If it doesn't, please get back to us.  Thank you for being a Samsung customer!
mleppelman
LED and OLED TVs
I bought new high speed HDMI cables when I bought the TV.
