Slow Apps
(Topic created: 01-17-2025 12:36 PM)
Allessio
LED and OLED TVs
I bought a 65" S90D in Nov 2024, and noticed how much slower the navigation in apps like Paramount+, Max, and Netflix is compared to the RUKU device I was using on my old TV. Is this expected? or a problem? And can I do anything about it.
Samsung_Moderator
LED and OLED TVs
I would check to make sure the TV is up to date on the latest firmware/software as well as checking to make sure the internet connection is strong. Sometimes if the TV is connected via Wi-Fi, it'll be a smidge slower than if it were connected via ethernet directly. If the slowness only happens in specific apps, you will need to reach out to the app developers directly and see if there's anything they can do on their end to fix it
1 Reply
Samsung_Moderator
LED and OLED TVs
