Remote not working and red light flashing
(Topic created: 08-12-2019 06:24 PM)
OCRFierce
Projectors & Other TVs
Hello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about.  How frustrating!  I have read through the posts and tried everything, yet i cannot get any of the functions to work.  Everything has worked perfectly for over a year.  I’m so confused, please help.
I have UN65KS9500FXZA.
JUMP TO SOLUTION
OneKiowa
That's a pretty important step to leave out! Thanks for the info....
BiGphilly86
This worked for us.  un65ku7500sxnz. our remote stopped working last night, it would turn on and off the tv but any other button used would display "not available". the remote red like would just keep flashing aswell. i tried many things like powering off tv , removing plug for a few minutes but no luck. after going through few forums i was ready to buy a new wifi module from ebay. i found this option today and sent it through to my wife to try and boom! its working.
Massive thank you
users2JOYwcu6M
This solution did not work for me. Thanks!
userwlz4PiLqAU
Back and play/pause worked for me. Tv started to sync with remote.
userVLKjTVOVcy
Same for me, Back and >ll (play/pause).
uservB8zBi5fSS
Thank you for the solution!
userSN200ZWmzF
I'm having the same issue but I'm not getting it to work. I've tried replacing the batteries, doing the re-sync and it's not working. Just getting the "not available" message or nothing at all...Just bought the tv last month.
No solutions posted in any of the several forums work for me.
I need replacements from Samsung. Overnighted.
koce1102
Previous posted solution Return+up button not wlrking for me.
I own samsung smart remote.
How to remove from tv(unpair) ?
So I can tdy different remote...
Not applicable
Remove the batteries from the old remote. Pairing the new one will automatically remove the old pairing.
