Remote not working and red light flashing
(Topic created: 08-12-2019 06:24 PM)
OCRFierce
Projectors & Other TVs
Hello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about.  How frustrating!  I have read through the posts and tried everything, yet i cannot get any of the functions to work.  Everything has worked perfectly for over a year.  I’m so confused, please help.
I have UN65KS9500FXZA.
JUMP TO SOLUTION
user3TCyJI2uaU
Hi - I tried several times to do the back button, volume up for 20 seconds wiht the TV off, no luck.  I've changed the remote batteries twice, any alternate ideas?
Thanks.
SamsungJam
I would be happy to look into this.  Which model television/remote version do you have?
user3TCyJI2uaU
Thank you!
TV Model #UN43MU6300F
Not sure how to tell you what remote, it's the simple remote that came from the TV, not the universal type of remote from my cable provider.  It has:
- power button
- microphone button
- 123 button
- button with four colored dots
- round button in the middle with the up/down/left/right circle control
- back arrow button
- home button
- play/pause button
- volume up/down
- channel up/down
SamsungJam
Which software version is running on the television?
user3TCyJI2uaU
Release - APR-6.9
Build Number - 26.61
UI Version - 26.60
Middleware Version - 26.60
Does any of that help?  I don't see anythign that says software version.
Not applicable
Go to Settings>Support>Software Update and it should show Current Software Version. If it is not there, check in Settings>Support>Contact Samsung.
user3TCyJI2uaU
So when I go to Settings > Sysetm Information > (no support option)
It says "From the main menu, choose settings, then sysstem information to view information about the software, hardware, entework, and the current configuration of your Verizon Fios TV System"
But doesn't actually show me any of this.
Streaming server status is version 5.6, that's all I can see that shows a version.
Firmware version is:
KA25.04.04.15ALDER.9DB2F5DB
Not applicable
I believe you're just using the Verizon remote. The Samsung TV options would not include Fios.
user3TCyJI2uaU
Ok, but my samsung TV remote is the one that isn't working, so where should I go from here?
Not applicable
Use the button toggle on the bottom of the television screen to navigate to the settings.
