- Mute
08-12-2019 06:24 PM (Last edited 08-12-2019 06:48 PM ) in
Projectors & Other TVsHello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about. How frustrating! I have read through the posts and tried everything, yet i cannot get any of the functions to work. Everything has worked perfectly for over a year. I’m so confused, please help.
I have UN65KS9500FXZA.
Solved! Go to Solution.
![](/skins/images/08F323EF0ED3E92B184F5BD7BE1EA6C3/responsive_peak/images/icon_anonymous_message.png)
- Mute
08-14-2020 09:40 AM in
Projectors & Other TVsWe are sorry to hear about this. Can you provide the television model number, please?
![Samsung Moderator Samsung Moderator](/i/rank_icons/moderator.gif)
- Mute
08-15-2020 12:50 PM in
Projectors & Other TVsAlso, does it seem like any buttons are stuck on the remote?
- Mute
08-15-2020 06:30 AM in
Projectors & Other TVsHave a 65 QLED 2019 model. Remote stopped working. REplaced batteries after draining and trying to reset/repair. Unplugged TV. Still not working. Called Samsung 4x, waited on hold for hours. Qued for call and have not received class over 3 days doing this. Site says open 7 days week, no answer on Saturday.
Red light flashing on the remote. No manual button to turn on TV. Need help!
- Mute
08-19-2020 11:43 PM in
Projectors & Other TVsI had this problem too and tried many of the "re-pair by pressing button x and button y" but this didn't work for me. I popped the remote open and cleaned the buttons, contacts and casing. When I put it back together, it worked. Basically, a button was pressing the whole time.
If you point your mobile phone camera at the remote light, you can see if it is on (all the time) or not. Hope this helps someone else.
- Mute
08-24-2020 07:44 PM in
Projectors & Other TVsI tried the above suggestions but it didn't work. However, for some reason when the tv came on, it gave me a message "unable to pair, press the back button & the play/pause button simultaneously" I did that for 20 seconds, the red lights stopped flashing & the tv paired with the remote again. Yay!!!
- Mute
09-21-2020 12:07 PM in
Projectors & Other TVsTHANK YOU!!!!! THIS WORKED FOR ME! I tried everything in the comments and this worked for me! Thank you for sharing this.
- Mute
08-31-2020 01:00 AM in
Projectors & Other TVsHaving the same problem, constant flashing red light when on. Remote temperamental and a "not available" box in the bottom left corner.
- Mute
09-04-2020 04:48 AM in
Projectors & Other TVsHello. I'm having the same exact issue with my TV and original remote. When I try to re-pair it says "Not Available". Please Samsung help.
- Mute
09-17-2020 03:32 PM in
Projectors & Other TVsHello- I'm having the same issue with a 8 series. None of the afformentioned recommendations worked. Not sure what to do here. I literally just took it out of the box and it doesn't work.
- Mute
09-21-2020 05:43 PM in
Projectors & Other TVs![](/skins/images/08F323EF0ED3E92B184F5BD7BE1EA6C3/responsive_peak/images/icon_anonymous_message.png)
