Remote not working and red light flashing
(Topic created: 08-12-2019 06:24 PM)
OCRFierce
Projectors & Other TVs
Hello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about.  How frustrating!  I have read through the posts and tried everything, yet i cannot get any of the functions to work.  Everything has worked perfectly for over a year.  I’m so confused, please help.
I have UN65KS9500FXZA.
JUMP TO SOLUTION
userIF2lDND0e7
Sigh, I have the same problem with a KU6270.  I have tried two new remotes and everything I have read about to have them pair with the TV.  Always, "not available."  Contacted Samsung and, though this is a common problem with their TVs, they told me I'd have to pay to have the motherboard replaced as the TV is 3 years old and out of warranty.  A $1,000 TV should not have problems after only 3 years.  Sounds like it is time for a class action law suit for defective products.
userdFn2rwPawV
Multiple times a day, all the buttons stops working on the remote except the power button. Had to reconnect the remote by pressing the back + play/pause buttons together.
Tried removing the battery  - Did not help
userah6bywEI3J
This one worked for me. My power was the only thing working to turn on/off my QLED 6 Series 2018 model. Red light blinking. I held the return/back button and play/pause button for about 10-15 seconds and the remote paired with the TV! Praise be!
userhJkLZqXNti
I have the same issue, but pressing the buttons didn't work. It did allow me to turn on the TV though.
SamsungJam
Just for clarification are you using the stock remote or a 3rd party universal remote
userA1OtTk33jS
same thing just happened to me... but this solution of holding the back and up button isn't working.
userz06e6hZVm8
Unplug television for reset. Repair is printed inside rear battery cover.....(back+play buttons) will repair Samsung remotes. 16032068273296442770927077242806.jpg
userPcq5dX3zQC
Same thing happened to me and nothing worked until I unplugged my tv for 10 to 15 seconds and it paired on its own after that.
users2JOYwcu6M
None of the solutions worked for me, thanks!
useriprcUfaH2k
Same here. Nothing works for me..
Samsung us junk
