- Mute
‎07-27-2023
11:34 AM
(Last edited
‎11-06-2023
01:33 PM
by
SamsungJustin
) in
Get ready to be on the phone with Samsung every 3 months, whatever hardware component they use for their networking is absolutely garbage. The television will display that it is still connected to wifi but nothing will load. Each agent will just spend 10 minutes putting you on hold then 5 minutes trying to reset all of the network setting. I bought this television less than 2 years ago and its an absolute cheap piece of
DO NOT BUY SAMSUNG, QUALITY IS !
Solved! Go to Solution.
- « Previous
- 1
- 2
- Next »
- Mute
‎07-28-2023 12:26 PM in
Projectors & Other TVs- Mark as New
- Mute
‎08-01-2023
12:28 PM
(Last edited
‎10-27-2023
12:12 PM
by
Samsung_Stephan
hey JB
i have one more Samsung cu8000 question. I've always used my ps5 to stream. but with this tv when i switch to ps5 from the tv apps the color gets washed out. I've tried it with game mode on auto, but even with the game mode off it still loses all the adj color settings settings. the ps5 doesn't really have any color settings. i like using the ps5 for streaming s it never has a problem seeing the internet instantly. thoughts?
thanks
mike
- Mute
‎10-14-2023 05:20 PM in
Projectors & Other TVsI agree with you 100%. Nothing but wifi issues with the cu8000. Mine connects but then over the course of a week, the wifi connection degrades and then I have to reset the network connection and the process starts over. My 2020 and 2021 models have no issues, but the 2023 has been nothing but problems since day 1. Support has not real solution. I have reached out to the BBB. Next will be hitting up executives on social media to get some attention on this. There is a defect in the firmware or wifi card.
- Mute
‎10-26-2023 07:22 PM in
- Mute
‎10-26-2023 07:24 PM in
Projectors & Other TVsEither replacing components or just buying a new TV will fix my issue as per Samsung suggests their is no service center within a 100 miles of my area
- « Previous
- 1
- 2
- Next »
