Does 2021 Samsung Frame 75" mount holes matches with 2024 65" Frame TV?
(Topic created: 01-23-2025 02:01 AM)
janakavishwajith
QLED and The Frame TVs
My previous house owner have had 2021 Samsung frame 75 inch TV. Now I am planning to buy a Samsung frame 65" TV. I am wondering whether can I use same drill-holes used for the 75" TV to mount Frame 65" TV?
Samsung_Moderator
Hello! Thank you for reaching out! I would recommend looking at the spec sheets for the TV to make sure for 100% but as long as the VESA mount is the same it should be fine. You can compare them using the Samsung website and look up your model number there.
1 Reply
Samsung_Moderator
