QLED TV HELP. Suddenly when I adjust volume the TV TALKS ... and tells me what it's doing. How do I fix this? Thanks
(Topic created: 05-12-2024 03:46 AM)
Dobeluvr
Nebula
QLED and The Frame TVs
bill-e
Cosmic Samsung Care Ambassador
Smart Hub->Settings->All Settings->General and Privay->Accessibility->Voice Guide=OFF
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
bill-e
Bill
userR5BiwDfqYp
Where is "accept as a solution?" It's not under options or visible to me anyplace.
bill-e
If using a browser it's under Options in the upper right of the post that you want to accept.  If using Members app is the 3 dot menu of the post that you want to accept.
I assume that worked? 😉  Weird how things just turn on sometimes.
Bill
