2021 Frame TV mounting dimensions for 55 inch
(Topic created: 03-16-2021 02:04 PM)
userJkpUPWpdQh
QLED and The Frame TVs
I am framing a wall to put up a 55 inch 2021 Frame TV that is on back order.
Does anyone have the dimensions between the mount points for the slim wall mount?
It seems that there are 2 mount points now, and I have to mount 2 different brackets to 2 different studs on the right and left hand side of the TV.  There is a few manuals online, but none of them show these measurements.
I want to ensure that I put studs in the proper location.
usermXNzp6gFKs
Not applicable
Could you please provide the model number for the television?
userJkpUPWpdQh
QN55LS03AAFXZA
usermXNzp6gFKs
