How does charging battery to 85% help keep battery life longer?
(Topic created: 09-04-2023 08:03 AM)
ybarshavit
Halo
Samsung Apps and Services
Hello, I have a question about battery charging. How does charging to 85% helps keep the battery life longer?
VerbumVeritum
Galactic Samsung Care Ambassador
Theoretically, due to the nature of lithium-ion batteries, it is to reduce the strain on the battery as it approaches 100%. This lessens the number of battery "cycles" (0-1+) per charge. If you're using a phone over many years, this setting might prove useful. If you upgrade frequently, I wouldn't worry about enabling this function.
VerbumVeritum
ybarshavit
Halo
Thank you!
VerbumVeritum
My pleasure! 🙂
