- Mute
02-08-2024
09:58 AM
(Last edited
02-29-2024
02:38 PM
by
SamsungTam
) in
I bought and just set up a WW25B6900AW front loader washer and the manual states that as part of the setup it does a calibration. I was not asked to do a calibration after choosing my language. It went right to the tutorial.
How can I run the calibration?
Also the tutorial always displays every time I turn on the washing machine even though I already completed it. How can I stop it from showing every time?
Solved! Go to Solution.
- Mute
02-08-2024 12:56 PM in
Washers and DryersNever mind I found the instructions on page 44. I'm not sure why it didn't ask to do calibration when I set it up though:
Calibration
You can run calibration again for accurate weight detection.
1. Tap and hold Options for 3 seconds.
2. Turn the Navigation dial to select Calibration, and then tap OK.
- Calibration does not start if the door is not closed properly.
- The drum rotates clockwise and anticlockwise for about 3 minutes.
3. When calibration is complete, the “Calibration complete” message appears on the display and the
washer turns off automatically.
- Mute
Calibration
![](/skins/images/BF379B214BB541DD06F2779EB1969D5F/responsive_peak/images/icon_anonymous_message.png)
