Turning off sound on washer and dryer
(Topic created: 05-02-2022 07:15 AM)
user5OZUeKo8zo
Washers and Dryers
We have the  DVE45A6400V washer and DVG45A6400V dryer, Is there a way to turn all of the sounds off?
Samsung_Moderator
Washers and Dryers
I totally understand how frustrating that is and am delighted to assist you! 🙂 For your dryer and washer alarm sounds, you can do the following troubleshooting steps:
You can enable/disable alarm sounds.
1. Tap and hold Options for 3 seconds.
2. Turn the Navigation dial to select Alarm, and then tap OK.
3. Tap OK to select On or Off.
   The default setting is On.
For more information, you can check out your user manuals:
 Dryer: https://downloadcenter.samsung.com/content/UM/202107/20210720031129782/DV8600A_DV8800_SimpleUX_DC68-...
Washer:
https://downloadcenter.samsung.com/content/UM/202203/20220308165332878/A1-WF6400-MD_DC68-04006Z-00_E...
1 Reply
Samsung_Moderator
Washers and Dryers
Washer:
