Remote not working and red light flashing
(Topic created: 08-12-2019 06:24 PM)
OCRFierce
Projectors & Other TVs
Hello.
Looks like I just fell into the same Remote ‘flashing red, not pairing, not available, tv turning on by itself in the middle of the night’ black hole I’ve seen posted about.  How frustrating!  I have read through the posts and tried everything, yet i cannot get any of the functions to work.  Everything has worked perfectly for over a year.  I’m so confused, please help.
I have UN65KS9500FXZA.
JUMP TO SOLUTION
usergqTelJ11qT
This worked. Thanks.
SamsungTam
You're very welcome! Have a wonderful day! 🙂
userQt0iTfd9y3
Works for me too. thank you
userzpeo2Chnwd
This one work for me instead the back + up.
user0OiqJ5e8wv
Your a life saver!!! This works!
user6JfrF4w8QS
I am having this same problem. My remote keeps flashing red light even when tv is off and remote does not work
userhJkLZqXNti
Hello, I am having the same problem. Remote #BN59-01301A
the remote will not control the TV at all. I purchased this from a Best Buy just over 8 months ago.
are there specific buttons to push for this remote?
I have replaced the batteries several times. Including purchasing new, just to confirm my stock of batteries weren't just old.
thank you.
userVel43f88D2
Yes
SamsungRei
Will you please send a private message with the serial number of the TV so I can look into this further? http://bit.ly/2XERsky
chrisjan
Had the same problem and found a solution in a separate forum:
Try pressing the back button + the UP button at the same time for 10-20 seconds.
This will re-pair the remote w/ the TV and fix the issue. 🙂
