- Mute
06-18-2024 04:08 PM in
A Series & Other MobileSolved! Go to Solution.
- Mute
06-19-2024 06:01 AM (Last edited 07-22-2024 08:45 AM by SamsungRei ) in
A Series & Other MobileHey there! I absolutely understand how concerning it can be when your device feels like it is overheating. While they may feel warm under certain conditions, like charging, this does not affect the device's lifespan or performance. However, if your devices get too warm, it could cause some issues. Give this link a try: https://www.samsung.com/us/support/answer/ANS00076952/ You can also try clearing the cache partition of the phone.
Turn off the device.
Press and hold the Volume Up key, then press and hold the Side key.
When the green Android logo displays, release all keys ('Installing system update' will show for about 30 - 60 seconds before showing the Android system recovery menu options).
Press the Volume down key several times to highlight wipe cache partition.
Press Side key to select.
Press the Volume down key to highlight yes, them and press the Side key to select.
When the wipe cache partition is complete, Reboot system now is highlighted.
Press the Side key to restart the device.
If you're still having the same problem I would suggest doing a factory data reset on the device.
https://www.samsung.com/us/support/answer/ANS00062029/
If your phone is getting too warm to touch, repairs would be recommended in order to have the technicians evaluate the device. You can use the following link to find a list of service centers in the U.S. that can do the repair: https://www.samsung.com/us/support/service/ or by contacting customer support at 1-800-726-7864.
For service outside of the U.S., please use this link: https://www.samsung.com/us/common/visitlocationsite.html
- Mute
06-18-2024 06:50 PM in
A Series & Other Mobile-------------------------------------------------------------
Please mark any response that helped you as your solution.
- Mute
