Microphone problems when making phone calls
(Topic created: 09-24-2024 08:40 PM)
Timbo61
A Series & Other Mobile
When I make a phone call, I can hear everything perfectly.   No one can hear me.  What is my problem?  Help please
Timbo61
Thank you. Found the diagnostics and went through process 3 times. Mic 1 had issues each time. Guess I have to figure out how to get a replacement. Thanks again
meself
Honored Contributor
Adjust the volume press top button during call
ChaosSaber
Honored Contributor
Any bluetooth device connected? And have you tested your mic
LongHiker
Galactic Samsung Care Ambassador
@Timbo61 Sounds like you are have mute enabled or you have a microphone issue.
Have you tested the microphone using diagnostics in the Members app -> support -> Diagnostics?
Timbo61
