- Mute
01-29-2020 07:26 AM (Last edited 07-28-2023 06:27 AM by SamsungAdam ) in
Galaxy BudsI have bought a new pairs of galaxy buds. Actually this is the second time. The first one had this issue so I returned them. Even if I don't use them the case battery pecentage drops from green to yellow then red. I takes 2 days for cases to dead. Please advise me.
Solved! Go to Solution.
- Mute
03-24-2020 06:48 AM (Last edited 07-28-2023 06:26 AM ) in
Galaxy BudsHello, I understand how frustrating it is when you try to use the Buds and the battery has already drained.
Are you using the original charger that came with the Galaxy buds?
-If not I would recommend using the original charging cable.
Note: Use only Samsung-approved charging devices and accessories. Samsung accessories are designed for your device to maximize battery life. Using other accessories may void your warranty and may cause damage.
When did you start experiencing these symptoms?
Have you had a software update to your Galaxy buds recently?
Here's some tips and precautions when charging your Galaxy buds: https://www.samsung.com/us/support/answer/ANS00078081/
If you are still experiencing these symptoms after the troubleshooting provided, the Buds will need to be evaluated by a certified technician. For in-warranty repairs: Please feel free to reach out to us directly via one of the following options and include a link to this thread.
1. Facebook Messenger: http://m.me/samsungsupport
2. Twitter: https://twitter.com/messages/compose?recipient_id=18768513
3. Or you can use the following link below to request service. https://www.samsung.com/us/support/service/
4. Private message: https://bit.ly/3fbRevo
5. Contact customer service directly at 1-800-726-7864
For out of warranty repairs, please give this link a try to set up service for your buds: https://www.samsung.com/us/support/service/locations/ or you can reach out to our customer service team directly at 1-800-726-7864.
For international devices, please reach out to a support team in your area for further assistance: https://www.samsung.com/us/common/visitlocationsite.html
- Mute
01-29-2020 10:23 AM in
Galaxy BudsHey there!
Have you already tried resetting your buds through the wearables application?
- Mute
01-30-2020 01:08 AM in
Galaxy BudsYes, I did this but didn’t change anything. I will reset it again. I am going to discharge both buds and case and charge them to 100 percent and see if it fixes the problem or not. This issue has been reported many times in reddit. This is the second pair I have and both have the same exact issue. I really love them but it is forcing me to return them.
- Mute
01-30-2020 06:36 AM in
Galaxy BudsI'm sorry to hear this, please keep us posted once you reset them.
- Mute
01-31-2020 02:49 AM in
Galaxy BudsI reset them yesterday and drained the batteries completly then I charged them to 100. After that I just used the buds for 25 min then put them in the case. It was green for about 16 hours then it turned yellow. Except that 25 min I hadn't used them at all but it turned yellow. If it goes like before it turns to red very soon. The case loses juice without using the buds.
- Mute
03-24-2020 04:23 AM in
Galaxy BudsHave you received any updates on this? My Samsung Galaxy Buds+ have the same issue.
- Mute
- Mute
03-24-2020 07:03 AM in
I returned them and bought a new one. But They had the same problem. What I found is that it was my problem because I was opening the case cap regurly. When you put the pieces inside the case, after maybe 20 minutes the buds go to sleep mode and when you open them they turn on again which eats the battery. Now i just open the case when I need them and the problem has solved. If you open the case regularly stop it. If the problem persists I recommend you to to return them. You may wait until you get new firmware update. Maybe it's just software bug.
- Mute
04-27-2020 03:09 PM in
Galaxy BudsSame here. Charging case totally drains my right ear bud even are resetting as well as using Samsung approved chargers.
Please can we get a fix for this?!
- Mute
04-30-2020 11:15 AM in
Galaxy BudsI FINALLY FIGURED IT OUT!!! The ambient sound STAYS ON. I did a little test with my first gen earphones and my plus.... As soon as I turn the ambient sound off my battery was back to normal drain on my case. The regular buds lasted 2 weeks with the case and after the update the ambient sound is actually making my regular buds drop down too. The fix is to simply turn ambient off in the gear app and turn it back on when you want to use it!!!
