Phone not connecting to wifi
(Topic created: 11-14-2022 09:32 PM)
userQIPJLNYmuV
Galaxy Note Phones
Our phones in our home wont connect to our wifi and just say connection failed anyonw have any help to fix
userQIPJLNYmuV
Galaxy Note Phones
we contacted our provider and they were finally able to fix it so u may try them
d_spi
Supernova
Galaxy Note Phones
Good evening, I hope you're doing well
I'm sorry to hear that your phone isn't connecting to your Wi-Fi signal.
Try resetting your router first (usually there will be a small button it that will achieve this) if not, unplugging it for 15 seconds then plugging it back in will have the same affect.
Next go into your WiFi settings menu> tap on the gear icon next to your wifi name> then at the bottom select "forget" your wifi network then readd it. After doing this, your phone should connect to it no problem.
userQIPJLNYmuV
Galaxy Note Phones
i have done both of these multiple times and have reset network setting and still nothing i cant get any results
d_spi
Supernova
Galaxy Note Phones
Is it just your phones that won't connect to your router?
userQIPJLNYmuV
Galaxy Note Phones
yes everything else is fine
Kentaro
Galaxy
Galaxy Note Phones
Probably your router firmware needs update. Check your router brand website and support.
Piave
Galaxy Note Phones
I'm having the same issue . For 2 days now . Have tried everything I don't know what happened . Samsung zfold 3
userQIPJLNYmuV
Galaxy Note Phones
Pelé
Galaxy Note Phones
Sounds like an issue with your wireless router. Forget the network and try connecting via WPS
