S10/S10+ Led Notification Light Missing
(Topic created: 02-27-2019 07:54 AM)
Not applicable
Galaxy S Phones
Is the LED Notification light missing from the S10 phone, if it is is there a workaround to get it, or will there be an update and they will add it?
Also if it is, I am very disappointed and considering not getting the new phone.
JUMP TO SOLUTION
MikePasta
Halo
Galaxy S Phones
Just stumbled across this, 2 new apps to toss into the ring until Samsung gives us an official way. (If they ever do!)
https://www.xda-developers.com/galaxy-s10-notifications-battery-indicator/
I haven't tried either one... yet. Will try them out tonight and tomorrow.
truenliving7
Galaxy S Phones
You should try a new app called holey light it gives you led light it's a great app y'all won't be disappointed
RichieD0312
Galaxy S Phones
Yus
Galaxy S Phones
They should bring led notifications around the cutout in a update
userolBbAuhe8x
Cosmic Ray
Galaxy S Phones
The problem is that there are no leds to activate...
useraLmT18r3FT
Galaxy S Phones
Is this functionality to enable the LED around the front camera cutout for notifications actually being worked on?
There are third party applications that can light up that LED, but only if the screen is on.
We'd like to know if this camera cutout LED will actually work like the LED notifications used to work on models that had a bezel, even when the screen is off or the device is locked.
If it's being worked on, is there any estimate that can be provided on when this might be available?
Thanks.
userolBbAuhe8x
Cosmic Ray
Galaxy S Phones
THERE IS NO LED's on or in this phone
userOEoMPuislm
Galaxy S Phones
Oh, ok got it. I never realised this after reading 35 pages of comments. Thanks for your input.
CtrlZThis
Comet
Galaxy S Phones
It was updated yesterday and can confirm Good Lock edge lighting + does work with all of my apps including textra.
truenliving7
Galaxy S Phones
Holey light gives you led around the cutout and you customize to the color you like you can find it in the app store great app
