- Mute
- Email to a Friend
‎03-09-2020 07:02 PM in
Galaxy S20So I have a galaxy S20 ultra and having a problem with it charging wireless in my wireless car charger. At first I thought the charger might be defective or uncompatible with the phone. The charger works fine with my wife's S20+ but not the ultra. Also it works fine when I use both my wireless charger at home. The problem is it would charge then pause then charge then pause every 2 second. I tried turning fast wireless charging off and it still didn't change anything. Any help would be greatly appreciated.
Solved! Go to Solution.
- Mute
- Email to a Friend
‎05-12-2021 10:07 AM in
Galaxy S20I recommend that you follow these steps here
If these steps do not work then your unit will require service. Please feel free to reach out to us directly via one of the following options and include a link to this thread.
1. Facebook Messenger: http://m.me/samsungsupport
2. Twitter: https://twitter.com/messages/compose?recipient_id=18768513
3. Or you can use the following link below to request service. https://www.samsung.com/us/support/service/
- Mute
- Email to a Friend
‎03-10-2020 04:14 AM in
Galaxy S20Same issue here. Wireless car charger cycles on ultra but works with S10+ and Iphone pro max.
- Mute
- Email to a Friend
‎03-10-2020 01:38 PM in
Galaxy S20Same issue for me.
- Mute
- Email to a Friend
‎03-10-2020 05:39 PM (Last edited ‎03-10-2020 05:41 PM ) in
Galaxy S20The phone fits perfectly. I have tried it with the case off and the case on still no luck. Tomorrow I will try using the wireless charger on the wife car since its the same as mine. See if there any difference.
- Mute
- Email to a Friend
‎03-10-2020 08:27 PM in
Galaxy S20Same here. All our other phones charge fine on it too.
- Mute
- Email to a Friend
‎03-16-2020 08:34 AM in
Galaxy S20In what universe would that be acceptable, charging with a wire???
- Mute
- Email to a Friend
‎03-11-2020 12:57 AM in
Galaxy S20Gotta get the actual charger for the s20. My newest wireless charger won't keep up with my s20 unless I close down every app and shut it off otherwise its like using a regular charger and says something along the lines of "this phone uses to much energy to wireless charge" in not so many words. You need to wait for the wireless charger to come out for the s20. The processor is using to much to keep up with the low wattage of your wireless charger.
- Mute
- Email to a Friend
‎03-11-2020 03:31 PM in
Galaxy S20It like that since the phone was brand new with no new apps installed yet.
- Mute
- Email to a Friend
‎03-13-2020 05:30 PM in
Galaxy S20Yeah didn't work. Thanks tho
- Mute
- Email to a Friend
‎03-11-2020 01:04 AM in
Galaxy S20Never have had a issue with my s20 ultra charging wireless
