abazaba12345
- Mute
ā02-23-2025 10:08 AM in
Galaxy S22
Batteries having difficulty charging weather wirelessly or whether using a wall charger and the phone must remain plugged in and order to function semi properly once you unplug the phone it dies within 10 minutes and it dies within 10 minutes and shuts off and battery drains to about 30 to 60%. I must plug the phone in again in order to turn it back on and as long as it's plugged in it remains okay I'm replacing the battery I have it in the mall we'll see if this fixes it any suggestions
LongHiker
Galactic Samsung Care Ambassador
- Mute
ā02-23-2025 10:24 AM in
Galaxy S22
Replacing the battery does seem like the first step to take.
tera975
Nebula
- Mute
ā02-23-2025 10:47 AM in
Galaxy S22
How do you replace the battery? Is that a service thing? Now, I am asking for myself in case that ever happens to me.
kingCinchgy86
- Mute
ā02-23-2025 10:50 AM in
Galaxy S22
This is ducking crazy yo
meself
Honored Contributor
- Mute
ā02-23-2025 11:09 AM in
Galaxy S22
Would say battery is bad and need to replace
jt13890
Halo
- Mute
ā02-23-2025 12:39 PM in
Galaxy S22
Go to settings, battery capacity and the see how many mAh's it has. If it says something really low, it is a battery problem
Nanchi
- Mute
ā02-24-2025 06:51 AM in
Galaxy S22
My phone is tell 100% charger and within a few minutes it drains to 0%.
This suddenly started happening. Is anyone having the same problem?
